Saltar al contenido principal
Inglés
Español
Paso 10
Test for continuity of shielding between 30-pin connector and USB connector. The resistance should be much less than 1 Ohm.
Test for short circuits
  • Test for continuity of shielding between 30-pin connector and USB connector. The resistance should be much less than 1 Ohm.
  • Test for short circuits between the 4 pins on the USB connector. There should be none.
Pruebe la continuidad de la protección entre el conector de 30 pines y el conector USB. La resistencia debe ser mucho menor que 1 Ohm.
Compruebe si hay cortocircuitos entre los 4 pines del conector USB. No debería haber ninguno.
