Saltar al contenido principal
Inglés
Español
Traduciendo paso 1
Paso 1
Take a pin with a plastic head. Place the tip over a flat, heavy duty surface (such as a cold chisel blade) and tap with a hammer to flatten. This should only take 5 to 10 taps. Make sure the blade is flat and the edge is smooth.
Make a connector opener
  • Take a pin with a plastic head. Place the tip over a flat, heavy duty surface (such as a cold chisel blade) and tap with a hammer to flatten. This should only take 5 to 10 taps. Make sure the blade is flat and the edge is smooth.
Toma un alfiler con una cabeza de plástico. Coloque la punta sobre una superficie plana y resistente (como una cuchilla de cincel fría) y golpee con un martillo para aplanar. Esto solo debería tomar de 5 a 10 toques. Asegúrese de que la cuchilla esté plana y que el borde esté liso.
