Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 5 guías que incluyan este paso.
Inglés
Español
Paso 3
Unscrew the four 16 mm long screws from the back panel with a T10 Torx Screwdriver. Use a firm grip to peel off the back panel. It is sealed tight and requires a good amount of force to remove. Use a firm grip to peel off the back panel. It is sealed tight and requires a good amount of force to remove.
  • Unscrew the four 16 mm long screws from the back panel with a T10 Torx Screwdriver.
  • Use a firm grip to peel off the back panel. It is sealed tight and requires a good amount of force to remove.
Insertar traducción aquí
