Saltar al contenido principal
Inglés
Español
Paso 2
Carefully split/cut the copper tape (which protects parts of the motherboard from heat) with a razor blade to allow removal of the antenna wire. Be careful not to cut too deep and damage the wire.
Detach antenna wire from battery case
  • Carefully split/cut the copper tape (which protects parts of the motherboard from heat) with a razor blade to allow removal of the antenna wire.
  • Be careful not to cut too deep and damage the wire.
  • Unclip the antenna wire from the motherboard.
  • Unclip the antenna wire from each clip on the battery case (until the speaker).
  • Be careful not to rip the wire, however the wire should be strong enough and should come out with enough force.
Insertar traducción aquí
