Saltar al contenido principal
Inglés
Español
Traduciendo paso 7
Paso 7
Place the soldering iron onto the battery wire and metal connector for one to two seconds to heat them up.
  • Place the soldering iron onto the battery wire and metal connector for one to two seconds to heat them up.
  • Add the solder wire and wait for the solder to melt onto the wire. Once a small bead has formed around the wire, lift the solder away first and then remove the soldering iron.
  • Continue with the other two connections the same way, taking special care not to solder two of the connectors together.
Insertar traducción aquí
