Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 4 guías que incluyen este paso.
Inglés
Español
Paso 6
Using a Phillips 00 screwdriver, unscrew the two 3.9mm screws to the right of the cursor pad on the U-shaped frame. Turn the device over so the front of the camera is facing you. Using a Phillips 00 screwdriver, unscrew the two 3.9mm screws on the end casing.
End Casing
  • Using a Phillips 00 screwdriver, unscrew the two 3.9mm screws to the right of the cursor pad on the U-shaped frame.
  • Turn the device over so the front of the camera is facing you.
  • Using a Phillips 00 screwdriver, unscrew the two 3.9mm screws on the end casing.
  • Using a spudger, pry off the end casing.
Insertar traducción aquí
