Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 5 guías que incluyan este paso.
Inglés
Español
Paso 6
Remove the dual LED flash cover with a pair of tweezers. This is held on with a small amount of adhesive. Using a mildly heated pair of tweezers would ease the removal of flash cover as it helps weaken the adhesive . Remove gently as the flash cover may be glued to the antenna cable(s) below.
  • Remove the dual LED flash cover with a pair of tweezers. This is held on with a small amount of adhesive.
  • Using a mildly heated pair of tweezers would ease the removal of flash cover as it helps weaken the adhesive .
  • Remove gently as the flash cover may be glued to the antenna cable(s) below.
  • Use a pair of tweezers to disconnect the two antenna cables near the camera.
  • Some models of this phone will have only one antenna cable at this location.
  • Proceed to disconnect the antenna cable near the bottom right of the phone.
Insertar traducción aquí
