Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 5 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Accessing the internals of the 4th generation Shuffle is extremely difficult, as the rear panel is both glued to the front case and secured by metal retaining clips. It is highly unlikely that you will be able to remove the rear panel without inflicting cosmetic and/or structural damage.
  • Accessing the internals of the 4th generation Shuffle is extremely difficult, as the rear panel is both glued to the front case and secured by metal retaining clips. It is highly unlikely that you will be able to remove the rear panel without inflicting cosmetic and/or structural damage.
  • Before proceeding, be sure your Shuffle is switched off.
Acceder a las partes internas de la 4ª generación de Shuffle es extremadamente difícil, ya que el panel posterior está pegado a la caja frontal y está asegurado con clips de retención metálicos. Es muy poco probable que puedas quitar el panel posterior sin causar daños estéticos y / o estructurales.
Antes de continuar, asegúrate de que su Shuffle esté apagado.
