Saltar al contenido principal
Inglés
Español
Traduciendo paso 1
Paso 1
Check the water jets in the pool to see if the water is flowing at the normal flow.
  • Check the water jets in the pool to see if the water is flowing at the normal flow.
  • If you have an automatic pool cleaner and it has slowed down or stopped working, this is a sign that you may have some sort of filter or pump blockage.
  • Another way to check your water flow is to check the pressure gauge on your pool filter. Most pool filters have a pressure gauge attached to monitor the waterflow. When the pressure is higher than normal, this indicates that the filter may need to be cleaned or replaced.
Insertar traducción aquí
