Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 2 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 4
Paso 4
Use an iOpener or a heat gun to loosen up the adhesive securing the motherboard to the display assembly. Use a plastic opening tool to gently pry the motherboard free of the display assembly. At this point, the bottom speaker is still attached to the motherboard. If you are only replacing the motherboard, refer to the bottom speaker guide to swap your existing speaker to the new motherboard.
  • Use an iOpener or a heat gun to loosen up the adhesive securing the motherboard to the display assembly.
  • Use a plastic opening tool to gently pry the motherboard free of the display assembly.
  • At this point, the bottom speaker is still attached to the motherboard. If you are only replacing the motherboard, refer to the bottom speaker guide to swap your existing speaker to the new motherboard.
Insertar traducción aquí
