Saltar al contenido principal
Inglés
Español
Traduciendo paso 1
Paso 1
Rotate the LCD and its casing so that the screen is facing you. Gently pull the control panel downward, freeing it from the small metal clips. Lift the control panel away from the metal and carefully pull the ribbon-wire out as you do.
  • Rotate the LCD and its casing so that the screen is facing you.
  • Gently pull the control panel downward, freeing it from the small metal clips.
  • Lift the control panel away from the metal and carefully pull the ribbon-wire out as you do.
Insertar traducción aquí
