Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 7 guías que incluyan este paso.
Inglés
Español
Paso 2
Carefully insert a small flathead screwdriver or Jimmy in the seam between the metal casing and white plastic top. Use the screwdriver to pry up the white plastic top bezel. Be careful not to damage the soft plastic with your screwdriver.
  • Carefully insert a small flathead screwdriver or Jimmy in the seam between the metal casing and white plastic top. Use the screwdriver to pry up the white plastic top bezel. Be careful not to damage the soft plastic with your screwdriver.
  • The top bezel is held on with an adhesive, so it may be necessary to pry up in several different locations to free the part.
  • To make this job easier, heat up the adhesive with a hairdryer on low heat for a few seconds.
Con cuidado, inserta un destornillador plano pequeño en la costura entre la carcasa de metal y la tapa de plástico blanco. Utiliza el destornillador para levantar el bisel superior de plástico blanco. Ten cuidado de no dañar el plástico blando con el destornillador.
El bisel superior se sujeta con un adhesivo, por lo que puede ser necesario hacer palanca en varios lugares diferentes para liberar la pieza.
Para facilitar este trabajo, calienta el adhesivo con un secador a fuego lento durante unos segundos.
[* black] Carefully insert a small flathead screwdriver or [product|IF145-259|Jimmy] in the seam between the metal casing and white plastic top. Use the screwdriver to pry up the white plastic top bezel. Be careful not to damage the soft plastic with your screwdriver.
[* icon_note] The top bezel is held on with an adhesive, so it may be necessary to pry up in several different locations to free the part.
[* black] To make this job easier, heat up the adhesive with a hairdryer on low heat for a few seconds.
