Saltar al contenido principal
Inglés
Español
Paso 17
Don't worry, this UFO isn't here to abduct you. Not unless you're tiny, and ferromagnetic. It's just a centering magnet to ensure good alignment for charging. Looking at this Oreo cookie of a charger, we find the inductive coils in the lower section, and a dense weight in the upper portion. Speaking of density, here's a map with COLORS.
  • Don't worry, this UFO isn't here to abduct you. Not unless you're tiny, and ferromagnetic. It's just a centering magnet to ensure good alignment for charging.
  • Looking at this Oreo cookie of a charger, we find the inductive coils in the lower section, and a dense weight in the upper portion.
  • Speaking of density, here's a map with COLORS.
  • This fancy 3D graph shows the density of the charger's internals, with higher points representing greater density. That dark red semi-circle is the magnet, while the yellow indicates the charging coils.
Insertar traducción aquí
