Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Traduciendo paso 2
Paso 2
To separate the trigger assembly from the motor, use a soldering iron to melt the solder and pull gently on the red and black wires from the trigger. Heating the solder may melt the plastic packaging. Prior experience with soldering is required.
  • To separate the trigger assembly from the motor, use a soldering iron to melt the solder and pull gently on the red and black wires from the trigger.
  • Heating the solder may melt the plastic packaging. Prior experience with soldering is required.
  • The trigger assembly is Part #: 270001392
Insertar traducción aquí
