Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
Inglés
Español
Traduciendo paso 17
Paso 17
Boxee Box Repairability: 7 out of 10 (10 is easiest to repair) The Boxee has a separate power board that can be replaced independently from the motherboard, should it ever fail.
  • Boxee Box Repairability: 7 out of 10 (10 is easiest to repair)
  • The Boxee has a separate power board that can be replaced independently from the motherboard, should it ever fail.
  • All Phillips screws were used inside the device, requiring you to have just one screwdriver.
  • Once inside, all components come apart pretty logically.
  • The green rubber bottom of the Boxee Box is difficult to remove, and will never look the same once you've removed it.
Insertar traducción aquí
