Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
Inglés
Español
Paso 13
After removing a couple more Phillips screws, the motherboard can be removed from the rest of the metal frame. Once it's lifted out, the power button connector is the only thing keeping us from getting a closer look at the board. Once the motherboard is out, the bottom metal frame can be removed from the plastic outer casing.
  • After removing a couple more Phillips screws, the motherboard can be removed from the rest of the metal frame.
  • Once it's lifted out, the power button connector is the only thing keeping us from getting a closer look at the board.
  • Once the motherboard is out, the bottom metal frame can be removed from the plastic outer casing.
  • The power button switch and dual antennas are mounted to the bottom metal frame, making it one compact unit.
Insertar traducción aquí
