Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Inglés
Español
Paso 3
We had to peel off Boxee's lime-green rubber base and the adhesive sheet underneath to expose four #1 Phillips and two #2 Phillips screws. The #2 Phillips screws are clearly visible when you peel off the rubber base.
  • We had to peel off Boxee's lime-green rubber base and the adhesive sheet underneath to expose four #1 Phillips and two #2 Phillips screws.
  • The #2 Phillips screws are clearly visible when you peel off the rubber base.
  • The #1 Phillips are recessed, so you'll need a screwdriver with a longer shaft to access them.
Insertar traducción aquí
