Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 5
Use tweezers to peel up any adhesive left behind on the lower case. Also remove any adhesive that stuck to the Force Touch sensor. You may want to use an alcohol-soaked q-tip to clean any residue off the case. Be sure to let it dry before proceeding.
  • Use tweezers to peel up any adhesive left behind on the lower case. Also remove any adhesive that stuck to the Force Touch sensor.
  • You may want to use an alcohol-soaked q-tip to clean any residue off the case. Be sure to let it dry before proceeding.
Insertar traducción aquí
