Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Use a Y000 driver to remove the single tri-point screw securing the Force Touch sensor connector cable. This screw is very small and strips easily. Keep your driver at the correct angle and push to apply pressure to the screw as you turn.
  • Use a Y000 driver to remove the single tri-point screw securing the Force Touch sensor connector cable.
  • This screw is very small and strips easily. Keep your driver at the correct angle and push to apply pressure to the screw as you turn.
Insertar traducción aquí
