Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Traduciendo paso 18
Paso 18
For best results, apply heat from your iOpener, heat gun, or hair dryer to help set the adhesive. Then, detach the watch band and wrap a couple rubber bands around the Apple Watch's case for about 30 minutes to help the adhesive bond correctly.
  • For best results, apply heat from your iOpener, heat gun, or hair dryer to help set the adhesive.
  • Then, detach the watch band and wrap a couple rubber bands around the Apple Watch's case for about 30 minutes to help the adhesive bond correctly.
  • As a final check, power on your watch and make sure Force Touch works correctly—a hard press on the screen should cause the watch to vibrate, and the press should register on the display.
Insertar traducción aquí
