Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 15
If you're using a replacement battery that came with pre-installed adhesive, peel off the protective tab now, exposing the adhesive. If needed, try re-using the existing adhesive to secure the battery. Alternatively, try a small piece of double-sided tape such as Tesa 61395, or a dab of liquid adhesive such as E6000. Rotate the battery down into its slot, and press it into position.
  • If you're using a replacement battery that came with pre-installed adhesive, peel off the protective tab now, exposing the adhesive.
  • If needed, try re-using the existing adhesive to secure the battery. Alternatively, try a small piece of double-sided tape such as Tesa 61395, or a dab of liquid adhesive such as E6000.
  • Rotate the battery down into its slot, and press it into position.
  • Press the battery down against the system board to re-adhere it in place.
  • Now is the best time to test powering on your watch—if it doesn't turn on, double check all three connectors and try again.
Insertar traducción aquí
