Saltar al contenido principal
Inglés
Español
Paso 7
Use a metal probe to press against the hole located at the edge of the interior. While applying this pressure, pull on the shaft outward. Repeat this step on the opposite side.
  • Use a metal probe to press against the hole located at the edge of the interior. While applying this pressure, pull on the shaft outward. Repeat this step on the opposite side.
  • A small nut may fall out when the shaft is removed. Be careful not to lose the nut.
Insertar traducción aquí
