Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Paso 2
The wifi antenna is located below the volume switches.  Remove the tape and move the antenna to the opposite side.  The wires are soldered directly to the board, so, again, be gentle. Peel the tape off the battery and board.  Remove completely.  The battery is stuck down and is soldered to the board, so, again... Peel the tape off the battery and board.  Remove completely.  The battery is stuck down and is soldered to the board, so, again...
Remove wifi antenna and battery
  • The wifi antenna is located below the volume switches. Remove the tape and move the antenna to the opposite side. The wires are soldered directly to the board, so, again, be gentle.
  • Peel the tape off the battery and board. Remove completely. The battery is stuck down and is soldered to the board, so, again...
Insertar traducción aquí
