Saltar al contenido principal
Inglés
Español
Paso 5
Use a T15 Torx screwdriver to remove the dock from the base. Be careful not to damage the ribbon during this step. There is a torsion spring under the dock. When removed, this spring has a tendency to fly out. To avoid this, loosen the dock until it is able to move freely. Rotate it so that there is no tension in the spring. Then, you are free to undo the screw completely.
  • Use a T15 Torx screwdriver to remove the dock from the base. Be careful not to damage the ribbon during this step.
  • There is a torsion spring under the dock. When removed, this spring has a tendency to fly out. To avoid this, loosen the dock until it is able to move freely. Rotate it so that there is no tension in the spring. Then, you are free to undo the screw completely.
Insertar traducción aquí
