Saltar al contenido principal
Inglés
Español
Paso 3
Solder the red wire to the location noted here. You may need to replace or shorten your wire in order to make this connection.
  • Solder the red wire to the location noted here.
  • You may need to replace or shorten your wire in order to make this connection.
  • If this wire is damaged or too short, a new wire will have to be soldered at the speaker and the circuit board.
  • CAUTION: The soldering iron is hot and can melt/burn-out other components on the tablet. Avoid applying heat to any part of the tablet for extended amounts of time.
Insertar traducción aquí
