Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Traduciendo paso 1
Paso 1
Identify the Hard Drive in the case. If there is more than one hard drive installed the process is the same for each hard drive. Remove the power cable from the hard drive by squeezing the side tabs in and pulling gently.
  • Identify the Hard Drive in the case.
  • If there is more than one hard drive installed the process is the same for each hard drive.
  • Remove the power cable from the hard drive by squeezing the side tabs in and pulling gently.
  • Remove the IDE cable from the hard drive by gently pulling the ribbon cable out.
Identifica el disco duro en el estuche.
Si hay más de un disco duro instalado, el proceso es el mismo para cada disco duro.
Retire el cable de alimentación del disco duro apretando las pestañas laterales y tirando suavemente.
Retire el cable IDE del disco duro tirando suavemente del cable plano.
