Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 2
After successfully separating the casing insert a plastic spudger between the case and the speaker. Carefully pry the speaker out. Once the speaker is removed set the back casing aside. After successfully separating the casing insert a plastic spudger between the case and the speaker. Carefully pry the speaker out. Once the speaker is removed set the back casing aside.
  • After successfully separating the casing insert a plastic spudger between the case and the speaker. Carefully pry the speaker out. Once the speaker is removed set the back casing aside.
Insertar traducción aquí
