Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Paso 3
The 1000mAh 11.1V lithium polymer battery is attached via a connector, making it delightfully easy to remove. The second connector is a balance charge connector, which ensures that each of the three battery cells is charging equally, thus optimizing capacity and prolonging battery life.
  • The 1000mAh 11.1V lithium polymer battery is attached via a connector, making it delightfully easy to remove.
  • The second connector is a balance charge connector, which ensures that each of the three battery cells is charging equally, thus optimizing capacity and prolonging battery life.
  • The battery contains a protection circuit module, which prevents it from discharging too rapidly, over charging, or short circuiting.
  • Parrot claims the battery will only last about 12 minutes after a full charge, which takes around 90 minutes. Taking your AR.Drone out to the park with only one battery won't get you much play time, unfortunately.
Insertar traducción aquí
