Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y Herramientas
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 4
Locate and unscrew the four 3 mm screws using the Phillips #00 screwdriver. Unscrew the one T5 Torx screw using the special T5 Torx screwdriver head. The 2 mm T5 Torx screw is located on the motherboard near the antenna clip.
Remove Screws
  • Locate and unscrew the four 3 mm screws using the Phillips #00 screwdriver.
  • Unscrew the one T5 Torx screw using the special T5 Torx screwdriver head.
  • The 2 mm T5 Torx screw is located on the motherboard near the antenna clip.
  • If you aren't equipped with the T5 Torx screwdriver, you could try using your fingers, although it will be very difficult to remove it.
Insertar traducción aquí
