Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 5
Remove the wiring harness from the clip on the transmission Drain lines from the drum and drain hose are connected to the pump with spring clamps. Using a pair of pliers and squeezinge the opposite ends of the clamps together will loosen the clamp.
  • Remove the wiring harness from the clip on the transmission
  • Drain lines from the drum and drain hose are connected to the pump with spring clamps.
  • Using a pair of pliers and squeezinge the opposite ends of the clamps together will loosen the clamp.
Insertar traducción aquí
