Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Inglés
Español
Traduciendo paso 1
Paso 1
To disconnect the cable, use the spudger to unclip the small tab holding the ribbon in. Make sure you are unclipping just the tab, not the actual connector or ribbon Remove the connector with your fingers
  • To disconnect the cable, use the spudger to unclip the small tab holding the ribbon in.
  • Make sure you are unclipping just the tab, not the actual connector or ribbon
  • Remove the connector with your fingers
Insertar traducción aquí
