Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 4
Now for a look at the back of this cutting-edge device. We note the model number—SM-G925T—and get to work dispatching the back cover. Samsung stepped up the chic factor on the S6 and S6 Edge, opting for a screw-free glass back. This isn't exactly the first time we've seen this design trend. The rear panel is glued on rock-solid, and is a tight fit within the frame. Even with the adhesive patiently iOpened, we had to break out our Heavy Duty Suction Cup to slip in an opening pick. Definitely not fun.
  • Now for a look at the back of this cutting-edge device. We note the model number—SM-G925T—and get to work dispatching the back cover.
  • Samsung stepped up the chic factor on the S6 and S6 Edge, opting for a screw-free glass back. This isn't exactly the first time we've seen this design trend.
  • The rear panel is glued on rock-solid, and is a tight fit within the frame. Even with the adhesive patiently iOpened, we had to break out our Heavy Duty Suction Cup to slip in an opening pick. Definitely not fun.
  • Throwback to when Samsung had ultra user-friendly battery replacement doors. RIP.
Ahora miremos la parte trasera de este dispositivo de avanzada. Notamos que el número de modelo es SM-G925T— y nos ponemos a trabajar para despachar la tapa trasera.
Samsung redobló el factor chic el el S y el S6 Edge optando por una tapa trasera de cristal libre de tornillos. Esta no es exactamente la primera vez que vimos esta tendencia de diseño.
El panel trasero está pegado de forma sólida y está muy ajustado dentro del marco. Aún con el iOpener sobre el adhesivo, tuvimos que usar nuestra ventosa resistente para romper poder deslizar una púa de apertura. Definitivamente, no fue mu divertido.
Un salto atrás cuando Samsung tenía puertas para reemplazo de batería fácil de usar. Descansa en paz.
