Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 9 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 4
Paso 4
Use a plastic tool or your fingernails to carefully disconnect the orange headphone jack cable. Be sure to pull  straight up on the connector, not the cable itself.
  • Use a plastic tool or your fingernails to carefully disconnect the orange headphone jack cable. Be sure to pull straight up on the connector, not the cable itself.
  • This ribbon cable is very fragile. If you are replacing the battery, you can choose to skip this step and keep the headphone jack connected to the motherboard. Prop and tape the rear case against a box to keep it in place. Be very careful not to strain the fragile headphone jack cable as you work.
Insertar traducción aquí
