Saltar al contenido principal
Inglés
Español
Paso 2
Once you have the front panel off, you are one step closer to accessing the keys. From here,  you will need to remove the upper panel which will release the keys. Unscrew the screw and remove the small metal plate which holds the keys.
  • Once you have the front panel off, you are one step closer to accessing the keys. From here, you will need to remove the upper panel which will release the keys. Unscrew the screw and remove the small metal plate which holds the keys.
Insertar traducción aquí
