Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 10
Undo the earphone jack screw. (Notice: the screw is different than the rear housing screws.) Heat up the LCD Assembly to release the front housing. Pry up the navigation light stickers.
Release The Charging Port Assembly.
  • Undo the earphone jack screw. (Notice: the screw is different than the rear housing screws.)
  • Heat up the LCD Assembly to release the front housing.
  • Pry up the navigation light stickers.
Retire el tornillo del conector del auricular. (Nota: el tornillo es diferente que los tornillos de la carcasa trasera.)
Caliente la mica LCD para liberar la carcasa frontal.
Levante la mica con la ayuda de una pajuela o pinza plástica.
