Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
Inglés
Español
Paso 7
The last step is to crop your picture to a 4:3 aspect ratio. The guides will not accept any images of a different ratio. A key to cropping photos is to make sure that the subject of the photo is large enough, while also not so large that it overpowers the picture area. For example, the first picture is cropped too tightly as many edges contain very little white space. The second picture has good vertical margins, but poor centering.
Cropping
  • The last step is to crop your picture to a 4:3 aspect ratio. The guides will not accept any images of a different ratio.
  • A key to cropping photos is to make sure that the subject of the photo is large enough, while also not so large that it overpowers the picture area. For example, the first picture is cropped too tightly as many edges contain very little white space.
  • The second picture has good vertical margins, but poor centering.
  • The third picture shows a good picture crop, as there is some white space around the centered subject.
  • Cropping perfectly centered on the subject may not always be desirable. If there is a particular part or action occurring on the subject, you will want to center the crop around that. This may entail cropping part of the subject out of the picture.
El último paso es recortar tu imagen a una relación de aspecto de 4: 3. Las guías no aceptarán ninguna imagen de una proporción diferente.
La clave para recortar las fotos es asegurarse de que el tema de la foto sea lo suficientemente grande, mientras que no es tan grande como para que domine el área de la imagen. Por ejemplo, la primera imagen se recorta demasiado bien ya que muchos bordes contienen muy poco espacio en blanco.
La segunda imagen tiene buenos márgenes verticales pero mal centrado.
La tercera imagen muestra un buen recorte de imagen, ya que hay algunos espacios en blanco alrededor del sujeto centrado.
Recortar perfectamente centrado en el tema puede no ser siempre deseable. Si hay una parte o acción particular que ocurre en el sujeto, querrás centrar el recorte alrededor de eso. Esto puede incluir recortar parte del sujeto fuera de la imagen.
