Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 6
Not all work environments are perfectly clean, so subjects may end up with hair, dust, dirt or other imperfections on them. Major offenders should be removed if possible. Spot Healing and Clone Stamp tools are particularly useful for erasing imperfections without greatly affecting textured surfaces like in the pictures shown.
Spot Healing
  • Not all work environments are perfectly clean, so subjects may end up with hair, dust, dirt or other imperfections on them. Major offenders should be removed if possible.
  • Spot Healing and Clone Stamp tools are particularly useful for erasing imperfections without greatly affecting textured surfaces like in the pictures shown.
  • The Spot Healing tool used on this picture takes an imperfection and edits over it using details from the surrounding area. It is a good tool for fixing small blemishes (like the specks in our photo) since any inconsistencies that result from the editing are hardly noticeable.
  • The Clone Stamp tool is similar to the spot healing tool except you manually select what area you will be copying from. This tool is good for larger edits, but may require some extra touching-up to get the correct look.
  • Some imperfections may not be visible when placed into the smaller guide windows, but may be easily seen if the full sized image is viewed. Consider whether or not the imperfection would be visible under the greatest available zoom.
No todos los entornos de trabajo están perfectamente limpios, por lo que los sujetos pueden terminar con pelo, polvo, suciedad u otras imperfecciones. Los delincuentes mayores deben ser eliminados si es posible.
Las herramientas de reparación de manchas y tampón de clonar son especialmente útiles para borrar imperfecciones sin afectar mayormente las superficies texturadas como en las imágenes que se muestran.
La herramienta de reparación de manchas utilizada en esta imagen elimina imperfecciones y edita sobre ella usando detalles del área circundante. Es una buena herramienta para corregir pequeños defectos (como las manchas en nuestra foto), ya que las inconsistencias que resultan de la edición apenas se notan.
La herramienta tapón de clonar es similar a la herramienta de reparación de puntos, excepto que selecciona manualmente el área desde la que vas a copiar. Esta herramienta es buena para ediciones más grandes, pero puede requerir algunos retoques adicionales para obtener el aspecto correcto.
Algunas imperfecciones pueden no ser visibles cuando se colocan en las ventanas de guía más pequeñas, pero se pueden ver fácilmente si se ve la imagen de tamaño completo. Considera si la imperfección sería visible o no con el zoom más grande disponible.
