Saltar al contenido principal
Inglés
Español
Paso 3
Brightness and contrast adjustment is a good tool to use to perfect the lighting of your photo. Increasing brightness is the equivalent of adding light to the entire picture. The first picture shows an overly brightened picture to show exaggerated effects. Contrast, like mid-tone contrast, will simultaneously adjust darks and lights relative to each other. The second picture shows a high contrast setting which has caused the darks to become very deep and the whites to give off a sort of glare.
Brightness/Contrast
  • Brightness and contrast adjustment is a good tool to use to perfect the lighting of your photo.
  • Increasing brightness is the equivalent of adding light to the entire picture. The first picture shows an overly brightened picture to show exaggerated effects.
  • Contrast, like mid-tone contrast, will simultaneously adjust darks and lights relative to each other. The second picture shows a high contrast setting which has caused the darks to become very deep and the whites to give off a sort of glare.
  • For this picture, a slight increase in brightness is enough to properly light the object of the picture.
El ajuste de brillo y contraste es una buena herramienta para perfeccionar la luz de tu foto.
Aumentar el brillo es equivalente de agregar luz a toda la foto. La primer foto muestra una foto demasiado iluminada para mostrar efectos exagerados.
El contraste, al igual que el contraste de medio tono, ajustará simultáneamente las sombras y las luces entre sí. La segunda imagen muestra una configuración de alto contraste que ha provocado que las sombras se vuelvan muy profundas y que los blancos emitan una especie de resplandor.
Para esta imagen, un ligero aumento en el brillo es suficiente para iluminar apropiadamente el objeto de la imagen.
