Saltar al contenido principal
Inglés
Español
Paso 2
Adjusting the light levels may not be enough to even out all the darks and lights in a picture. To further correct the picture, you can adjust the shadows and highlights. Adjusting midtone contrast will increase or decrease the difference between darks and lights in your photo. You can see in the first image that there is a greater difference between the two than before adjusting the midtone contrast. Darkening highlights is useful for darkening particularly light spots in a picture without having to select that specific area.
Shadows/Highlights
  • Adjusting the light levels may not be enough to even out all the darks and lights in a picture. To further correct the picture, you can adjust the shadows and highlights.
  • Adjusting midtone contrast will increase or decrease the difference between darks and lights in your photo. You can see in the first image that there is a greater difference between the two than before adjusting the midtone contrast.
  • Darkening highlights is useful for darkening particularly light spots in a picture without having to select that specific area.
  • The Lighten Shadows tool is used for lightening particularly dark spots. Spots that contain detail (like the Nikon logo over the lens) may appear solid black; lightening shadows can bring out the detail. Use this tool only in small doses, though, as black objects are usually considered "shadows" in a program, and they will be lightened as well. Overuse of this function can also result in grainy spots.
Ajustar los niveles de luz podría no ser suficiente para emparejar todas las sombras y luces en una foto. Para corregir aún más la imagen, puedes ajustar las sombras y luces.
Ajustar el contraste de medios tonos aumentará o disminuirá la diferencia entre los tonos oscuros y las luces en su foto. Puedes ver en la primera imagen que hay una mayor diferencia entre las dos que antes de ajustar el contraste de medios tonos.
Los resaltados oscuros son útiles para oscurecer los puntos particularmente claros en una imagen sin tener que seleccionar esa área específica.
La herramienta aclarar sombras se utiliza para aclarar puntos especialmente oscuros. Los puntos que contienen detalles (como el logotipo de Nikon sobre la lente) pueden aparecer negro sólido.
Las sombras que se aclaran pueden resaltar el detalle. Sin embargo, use esta herramienta solo en pequeñas dosis, ya que los objetos negros generalmente se consideran "sombras" en un programa, y ​​también se iluminarán. El uso excesivo de esta función también puede dar lugar a manchas granuladas
