Inglés
Español
Traduciendo paso 1
Paso 1
Here is a bare bones photo of a Nikon D70 camera. The picture is pretty good, but could be improved in a few areas. The photo is too dark, has some incorrect colors, has some physical imperfections, and is not in the correct aspect ratio. A good way to start editing your photos is to adjust the light levels. Adjusting the light levels allows you to balance whites and blacks properly.
  • Here is a bare bones photo of a Nikon D70 camera. The picture is pretty good, but could be improved in a few areas.
  • The photo is too dark, has some incorrect colors, has some physical imperfections, and is not in the correct aspect ratio.
  • A good way to start editing your photos is to adjust the light levels. Adjusting the light levels allows you to balance whites and blacks properly.
  • Note that each side of the level graph contains multiple peaks. A good rule of thumb is to shift the light level sliders to just before the peaks on their respective sides.
Aquí hay una foto básica de una cámara Nikon D70. La fotos es bastante buena, pero podría mejorarse en unas pocas áreas.
La foto es demasiado oscura, tiene algunos colores incorrectos, tiene algunas imperfecciones y no tiene una relación de aspecto correcta.
Una buena forma de comenzar a editar tus fotos es ajustando los niveles de luz. El ajuste de los niveles de luz te permite equilibrar los blancos y negros adecuadamente.
Ten en cuenta que cada lado del gráfico del nivel contiene muchos picos. Una buena regla general es mover los deslizadores de luz hasta justo antes del pico de sus lados respectivos.
