Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 2
Paso 2
Run an opening pick around the edge of the screen to loosen it and begin to pry upward. When the screen comes up like it has in the photo, it should be able to simply be removed from its casing.
  • Run an opening pick around the edge of the screen to loosen it and begin to pry upward.
  • When the screen comes up like it has in the photo, it should be able to simply be removed from its casing.
  • The buttons on the end of the device will be loose when you remove the screen from the backplate. Be careful not to lose them.
Insertar traducción aquí
