Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 9 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 13
Paso 13
Gently lift the logic board assembly from the heat sink end and pull it away from the port side of the case to remove it from the Air. When replacing the logic board, insert the board's rubber edge under the port-side rubber gasket, then lower the board into place. When replacing the logic board, insert the board's rubber edge under the port-side rubber gasket, then lower the board into place.
  • Gently lift the logic board assembly from the heat sink end and pull it away from the port side of the case to remove it from the Air.
  • When replacing the logic board, insert the board's rubber edge under the port-side rubber gasket, then lower the board into place.
Insertar traducción aquí
