Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 9 guías que incluyan este paso.
Inglés
Español
Paso 6
Gently push the tip of a spudger under the black plastic flap stuck to the display data cable lock to make the lock pop upward and away from the socket. While holding the lock away from the socket, gently pull the display data cable out of its socket. Do not pull upward on the display data cable as you disconnect it, as its socket may break off the logic board.
  • Gently push the tip of a spudger under the black plastic flap stuck to the display data cable lock to make the lock pop upward and away from the socket.
  • While holding the lock away from the socket, gently pull the display data cable out of its socket.
  • Do not pull upward on the display data cable as you disconnect it, as its socket may break off the logic board.
Insertar traducción aquí
