Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 17 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 5
Paso 5
Lift, but do not remove the fan out of its recess in the upper case. Carefully pull the fan ribbon cable out of its socket as you remove the fan from the Air. Carefully pull the fan ribbon cable out of its socket as you remove the fan from the Air.
  • Lift, but do not remove the fan out of its recess in the upper case.
  • Carefully pull the fan ribbon cable out of its socket as you remove the fan from the Air.
Insertar traducción aquí
