Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 4
Up next, our favorite Air feature: battery removal. Thanks to this tidy plastic frame, the battery is held in with five screws and no adhesive—easy for fixers, easy for recyclers. It's a design carried over from previous models—but if yesterday's reveal is anything to go by, it could be on the outs. It looks to us like Apple didn't like wasting internal space on a plastic frame that could instead be more battery. In the absence of a frame, we're guessing those cells will get the glue treatment, signaling a continuation of the trend started by the Retina Pro.
  • Up next, our favorite Air feature: battery removal. Thanks to this tidy plastic frame, the battery is held in with five screws and no adhesive—easy for fixers, easy for recyclers.
  • It's a design carried over from previous models—but if yesterday's reveal is anything to go by, it could be on the outs. It looks to us like Apple didn't like wasting internal space on a plastic frame that could instead be more battery.
  • In the absence of a frame, we're guessing those cells will get the glue treatment, signaling a continuation of the trend started by the Retina Pro.
  • The battery specs carry over as well: the Air continues to sport a 7.6 V, 54 Wh, 7150 mAh battery. Thanks to the new Broadwell chips, we're supposed to get more life out of the same capacity: Now up to 12 hours of web browsing or video playback.
  • For all you scorekeepers, that's 2 Wh and a theoretical 1 hour more than the new Dell XPS 13.
A continuación, nuestra función Air favorita: extracción de la batería. Gracias a este ordenado marco de plástico, la batería se sujeta con cinco tornillos y sin adhesivo: fácil para los que lo fijan y fácil para los recicladores.
Es un diseño que se remonta a modelos anteriores, pero si la revelación del ayer es algo por lo que pasar, podría estar fuera de lugar. Nos da la sensación que a Apple no le gustó desperdiciar espacio interno en un marco de plástico que podría haber sido mas batería.
Si no tuviera un marco, suponemos que esas celdas recibirían un tratamiento con pegamento, lo que indica una continuación de la tendencia iniciada por Retina Pro.
Las especificaciones de la batería también se siguen: el Air continúa con una batería de 7,6 V, 54 Wh, 7150 mAh. Gracias a los nuevos chips Broadwell, se supone que obtendremos más vida con la misma capacidad: ahora hasta 12 horas de navegación web o reproducción de video.
Para los interesados, eso es 2 Wh y una hora teórica más que la nueva Dell XPS 13.
