Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 2 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Remove the three 13.25mm Phillips screws that secure the motherboard to the lower case with a Phillips head #2 screwdriver. Pull the motherboard assembly straight up and out of the plastic case with your hands. Turn the motherboard assembly over so the metal cover is facing you.
  • Remove the three 13.25mm Phillips screws that secure the motherboard to the lower case with a Phillips head #2 screwdriver.
  • Pull the motherboard assembly straight up and out of the plastic case with your hands.
  • Turn the motherboard assembly over so the metal cover is facing you.
Insertar traducción aquí
