Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 5 guías que incluyan este paso.
Inglés
Español
Paso 3
Remove the two silver 17.45mm Phillips screws from the cartridge tray using a Phillips head #2 screwdriver. Remove the two bronze 13.25mm Phillips screws from the cartridge tray using a Phillips head #2 screwdriver. Slide the cartridge tray toward you, away from the 72-PIN connector, and off the motherboard assembly.
  • Remove the two silver 17.45mm Phillips screws from the cartridge tray using a Phillips head #2 screwdriver.
  • Remove the two bronze 13.25mm Phillips screws from the cartridge tray using a Phillips head #2 screwdriver.
  • Slide the cartridge tray toward you, away from the 72-PIN connector, and off the motherboard assembly.
Insertar traducción aquí
