Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Using your fingers, remove the green tape holding the three ribbon cables down. Using the flat end of the heavy-duty spudger, carefully lift the black tab that holds the leftmost,  black ribbon cable in place. Repeat this step for the gold ribbon cable and the black ribbon cable. Using your fingers, gently slide each of the three cables straight out of the connectors.
  • Using your fingers, remove the green tape holding the three ribbon cables down.
  • Using the flat end of the heavy-duty spudger, carefully lift the black tab that holds the leftmost, black ribbon cable in place. Repeat this step for the gold ribbon cable and the black ribbon cable.
  • Using your fingers, gently slide each of the three cables straight out of the connectors.
Insertar traducción aquí
