Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 7 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
The plastic opening tool may break during this step. You may need to use the heavy duty spudger instead. Insert the plastic opening tool between the glass screen and the back cover so the curved end of the plastic opening tool is under the glass. Gently pry the back cover away from the glass screen.
  • The plastic opening tool may break during this step. You may need to use the heavy duty spudger instead.
  • Insert the plastic opening tool between the glass screen and the back cover so the curved end of the plastic opening tool is under the glass. Gently pry the back cover away from the glass screen.
  • Be sure to lift the entire display from the body and that you are not are lifting the glass from the display. You will need to reach down a little further for the correct removal.
  • Continue inserting the plastic opening tool around the whole device screen to completely separate the back cover from the glass screen.
Insertar traducción aquí
