Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 5
Be sure to insert the spudger underneath the charger port and not inside the charger port to avoid damaging the component Slide the flat end of the heavy-duty spudger under the charger port. Make sure the spudger is all the way to the back of the cavity and slide horizontally across the bottom to break the adhesive.
  • Be sure to insert the spudger underneath the charger port and not inside the charger port to avoid damaging the component
  • Slide the flat end of the heavy-duty spudger under the charger port.
  • Make sure the spudger is all the way to the back of the cavity and slide horizontally across the bottom to break the adhesive.
Insertar traducción aquí
